Gregoryewy
- Olathe, KS
It's sideways and needs to be rotated. :lol:
You missed the loadcenter in there didn't you?It is fine. It's a cabinet to me no plugs required....or is it no add a depths for the wood wall?? You need more info in your post
No receptacle plate on the GFCI.![]()
I would have added an Arlington plastic spark ring or equivalent.
Welcome to the Forum
Looks like the device box for the GFCI is flush with the finish to me so that shouldn't be necessary, they just need a trim plate.I would have added an Arlington plastic spark ring or equivalent.
If empty, why bother making access to it at all?maybe it is just an empty shell.
They did cut the back out of the cabinet, and is likely the shelves are easily removable.Where do you see access to it?
It may not be "readily accessible" but is still accessible. If it is just used as a junction box and no longer contains a panelboard there is nothing wrong there NEC wise, except for a missing cover on the GFCI.
