Re: When did UL drop Zinsco?
petersonra,
For some odd reason I expected to get a reply such as yours which made me reluctant to even post.
As I had stated, if one can't afford to change the panel and then is frightened by the potential hazard, then you have and issue of a person who is frightened to live in there home an can't afford to do otherwise. It's easy to drop a little bombshell, scare the daylights out of this little lady, and leave.
Under the circumstances it wasn't the right time.
Like I said, damned if you do and damned if you don't. And, yes, with all things taken into consideration on must consider the odds if a failure happening as compared to traumatizing a person.
Now that time has passed and she is under a lot less stress and has become accustomed to where she is in life I have no problem with telling her of my findings, that she should strongly consider changing the panel as she is able to afford to do.
If the Zinsco panel was that defective the I would like to believe that there would have been a concerted effort to educate the public via TV, Radio, newspaper, or what ever other means as to the danger of the Zinsco product, to have then removed and replaced immediately.
Don't get me wrong, I'm not trying to trivialize the problem because I beleave they should all be removed and replaced.
