When is a smoke detector required in garage per NFPA
aelectricalman
KY
If the garage is connected to a home by a breezeway, is it required? I should know this, but I don't. I always just do it. Im in a situation where it would required cutting alot of drywall. Thanks
Re: When is a smoke detector required in garage per NFPA
I thought smokes weren't required in the garage.
Doesn't it explicitly state in the instructions with the smoke not to install one there due to nuisance detecting?
Interested to see what others have to say.
NFPA 72
11.5.1* One- and Two-Family Dwelling Units.
11.5.1.1 Smoke Detection. Where required by applicable laws, codes, or standards for the specifice occupancy, approved single- and multiple-station smoke alarms shall be installed as follows:
(1) In all sleeping rooms
Exception: Smoke alarms shall not be required in sleeping rooms in existing one- and two-family dwelling units.
(2) Outside of each separate sleeping area, in the immediate vicinity of the sleeping rooms
(3) On each level of the dwellling unit, including basements
Exception: In existing one- and two-family dwelling units, approved smoke alarms powered by batteries shall be permitted.
5.7.1.8* Unless specifically designed and listed for the expected conditions, smoke detectors shall not be installed if any of the following conditions exist:
(1) Temperature below 0 degrees Centigrade(32 F)
(2) Temperature above 38 degrees Centigrade (100F)
(3) Relative humidity above 93 percent
(4) Air velocity greater than 1.5 m/sec (300 ft/min)
110.3(B) requires us to follow listing and labeling.
From BRK's website:
HEAT ALARMS
Heat alarms can be installed in areas not generally suitable for smoke alarms, including garages and attics.
Pierre
I'll just tie the reds (conditional hots) together and use the blacks as a light. It might be a good idea any how, because if the circuit ever quits working the light will not work. Therefore the homeowner will have more knowledge of the problem through a visible source and will be more apt to fix the circuit, assuring the smokes work.
