Is there a clear rule when you must upgrade a non compliant cable device etc. and if so how far back must you go?
Example: a 3 phase 480V motor change out the cable to the motor is innapropriate size to combo starter, Conductors feeding the combo are to small and tap fed from main feeder cable, the main feeder cable is to small for the OCP. Is there a clear rule on this? The AHJ doesnt help me in this case as the equipment is moved from site to site.............
I feel it needs to be upgraded.
Any input is appreciated.
