designer82
- Boston
The electrical panels in a multi-family building are pretty old, around 30 years or so.
I did a site survey and there were no code violations.
Is there an amount of time that the equipment should be replaced with new regardless or is the typical consensus to just run it to the ground?
One thing that comes to mind is the SC interrupt of the equip. I know the available fault current in this area has increased over the years and if the equip. from 30 years ago is only rated to say x and now over the years the available fault current is say 1.6x. would that be cause enough to consider a replacement?
