When the shoe fits...
wyreman
SF CA USA
electrical contractor
Track lighting has manufacturer's label that says:
"Do Not Cut"
:roll:
So what do you guys do if the track doesn't fit?
Buy small two foot pieces?
Chop saw with abrasive blade?
PortaBand?
thanks!
Make the room bigger:)
Find a track that will fit or can be cut.
Break the rules and cut it, may only loose warranty, may not pass inspection, may work just fine.
"Do Not Cut"
:roll:
PortaBand?
thanks!
Wow never saw a track that couldn't be cut?:confused:
Who ever this manufacture is just lost a few sales because being able to cut a track is essential to making the product installable in all locations, custom fit is a must for a good looking job, although you have to join tracks together to make a complete system, in most cases it looks much better when you can install a track with out joints, and I have had problems with loosing connection at joints so putting a bunch of tracks together is not my preferred method, as the less joints I feel is a more reliable installation.
most aluminum tracks I just cut with a carbide tip saw, I have used my 18 volt Dewalt to cut many tracks and it provides a nice clean cut as long as you don't try to force the blade, let the saw do the work and go slow, steel track I use my 18 volt Dewalt sawzall or a good hack saw, but again go slow and if no type of clamp table is available just screw the track to a board or exposed wall studs to hold it firm, and make sure you cut square, and also make sure the conductors don't slide out or they will be to short, I always cut the conductors about 1/4" shorter then the length of the track, or if one track end is in, 1/8" more off the other end to allow the other track end or coupler to fit, also try to keep the cut end where a track end blank will go, as if you don't get it square it doesn't show as bad.
Got a brand name to this manufacture? would definitely like to avoid them in the future.
I agree i would just cut it i don't see any reason why you can't:roll:
The last track I installed said...
DO NOT CUT
Unless necessary
I thought that was the funniest packaging I'd seen in a while - as if we would cut it just for sport. :)
DO NOT CUT
Unless necessary
:grin:
I always cut 1/16" off of tracks to keep in practice for when the time comes it is necessary.
