Here in a suburb of Detroit, copper and iron plumbing pipe is being replaced by plastic. Older residential service panels were grounded by connection with ground clamp to the nearest cold water pipe with #6 or #8 copper wire. There was no evidence of a driven ground rod. Building Rehabilation Codes often require "one for one" or replacement with the same. This would require a system ground connection to the metal underground water pipe only.
When does the code require a connection to newly driven ground rods per current code?
When was it that ground rods were required for residential services?
Knowing this date, it would be apparent if the service was installed in violation and therefore in need of driven rods in addition to waterpipe.
Thanks
Thanks
