Found myself having to pull 3x #10 through a 1/2" underground rigid, and I had no help. Pulled in a mule tape, then put the spools on a pair of pipe stands so they could feed downward. Ran the wires through a funnel and shoved the funnel into the pipe. Filled the funnel full of polywater J, had to go refill it a couple times during the pull. Total success couldn't have asked for the project to go smoother. Maybe this is a common method, I hadn't seen it before and thought I came up with a pretty good solution.
