Dale Hayes
Non-fusible disconnects can obtain a higher SCCR rating when protected with the appropriate fuses. For example: A 1200Amp non-fusible disconnect switch can be rated at 100kA SCCR when used in conjunction with a 1200amp type 'L' fuse. Where does the fuse go? Does the fuse connect to the line tabs on the non-fusible disconnect switch? Is the fuse mounted to separate fuseblocks? Is there any standard procedure for fusing a non-fusible disconnect? Unfortunately, the manufacturers of the fuse and switch show nothing about assembling the combination.
Con"fused" in Missouri.
