Hi.
A single phase 250v motor has a code letter G. (5.6-6.29).
The motor is 2HP with a FLA of 8.3 amps.
At 2 x 6.29 x 1000 / 240 = 52.42 LRC
The starter will be a nema O rated 18 amps.
The circuit will be 12 amps (as per table 430.248 2HP) x 1.25 = 15 amps ( 15 or 20 amp circuit )
The starter is based on the HP and FLA of the motor, the breaker is based on the FLA.
Where does the LRC come into play and where is it used in the circuit lay out?
Thank you.
Thank you.
