My electric utility requires a sub-meter in the 240 volt circuit feeding an EV charger plugged into a 14-50 receptacle. The meter socket is downstream of the main panel, so the neutral wire must not be bonded to the ground. The utility company says to simply run the neutral wire straight through the meter socket after removing the neutral lug first. Okay, fine. But, should the neutral wire be routed straight though the socket, behind the standard/bracket to which the main power lugs are found, Or, should the neutral be routed to one side of the main power lugs, making them visible for inspection? Seems like the former would offer less chance for any possible future cracking of the insulation due to no bends, but the latter offers immediate inspection opportunity that routing the wire behind the bracket does not. Which is the recommended location for routing the neutral wire?
