NetNathan
Net is where I be and Nathan is me
- Corona, CA
- Mgr. Electrical and Controls Eng
I am running a pair of 4/0 Awg /3 conductor (with #4 ground) tray cables to a piece of equipment using a below ground level covered trench using cable tray (basket style).
I need to come out of the underground tray into conduit to go up about 10 feet.
I want to strip the outer covering from the cable before entering the conduit, so only the insulated wires enter the conduit. This is to reduce the bend radius requirement of the multi conductor cable before entering the conduit.
Is there an NEC code relating to this strip distance?
Cable used:
https://www.wireandcableyourway.com/4-0-3c-thhn-pvc-tray-cable-with-ground.html
Cable Tray used:
http://www.cableorganizer.com/p/wirerun-powder-coated-cable-tray/
Cable used:
Cable Tray used:
