rrc14
- Anchorage, AK
- Engineer
Let me describe the equipment setup before I ask my question(s).
There are two disconnect switches, one is installed after the service entrance, then the feeder runs 1000', and terminates into another disconnect switch installed on the side of the building before hitting the distribution equipment. Basically, its a circuit that is 1000' long with disconnect switches on each end. The feeder is sized for 100A at 480V three phase.
My questions are regarding which disconnect needs to be fused, or if both need to be fused? I would fuse both disconnects, however, the engineer is indicating that may introduce a coordination issue?
I would appreciate any of your thoughts.
RC--
RC--
