trobbins313
I am preparing a report for a school that has a separate building (Mini-school) at the back. The main building is served by a 2000Amps service switch. The 2000Amps service switch feeds the Main Switchboard for the main building. The same service switch is also feeding a 600A fused disconnect switch located at the mini school. The 600A disconnect switch feeds panels located at the Mini-school. The Mini-school has a separate asset number therefore it’s considered a separate building. Which switch should I identify as the service switch for the Mini-school, the 2000 Amps located in the main building or the 600 Amps located at the Mini-school? Is there a code reference I can use for this?
