I'm curious which voltage drop formula you all use for standard roadway lighting or other circuits. I have come across three and all offer slightly different results (based on the complexity of the formula). My local resources show to use #1 as the default formula, however I have seen #2 and #3 used elsewhere.
1) The simple VD = 2 x K x I x D/CM
2) The IEEE Formula http://www.dolphins-software.com/voltageDrop.htm
3) The NEC Formula found in table 9.
