There is an electronic controller 120VAC, 0.5Amps max. This controller came with a 3 conductor cable with a 120V, 3 prong plug. I installed this controller on the side wall of an industrial control panel. I used suitable strain relief to pass through into the panel and terminated it to a 2 amp breaker in that panel. I had to cut off the 3 prong plug. The field inspector failed this installation and suggested to install a flexible conduit, and use single conductors. Do you think it is an error to permanently connect the original cable that came along with the controller? Your feedback is much appreciated. Thanks in advance.
