on a service call today I had a home owner recieving a small shock while in their whirlpool tub ( jaccuzi brand ) the pump motor is bonded back to the cold water line the pump is also on a gfi recp if I diconnect the bonding jumper I show 3.5 /4.5 volts between jumper and water line. If I put one probe in the water I show the same voltage. with everything back together and the main grnd cond loose from water service I show no voltage here. This voltage is present when the pump motor is unplugged. Any thoughts ideas would be helpfull
