Does this have to approved by UL or other third party before it can be sold?
Do you see any issues with it? beside the little extension cord is being used permanently.
Apparently you install the male plug at a lower level, install the female plug at a higher level (behind the TV) use the piece of romex to connect the two together, and use the extension cord to povide power.
http://www.amazon.com/Datacomm-50-3...7078732&sr=8-1&keywords=panel+mounted+voltage
