Who Had the Strictest Electrical Codes ?
mtnelect
HVAC & Electrical Contractor
Southern California
Contractor, C10 & C20 - Semi Retired
I say the City of Los Angeles. Until the Federal Housing Authority required Romex to build cheaper housing. Then changed to aluminum "Romex".
That is very interesting ... I thought that in order to get federal money today, the jurisdiction had to adopt federal guidelines.
maybe the got the courage to tell not take the dirty money.
I am surprised oregon has a hard test compared to national average. Though don't usually add too much to the code, they take out alot like all the dumb new GFCI requirements.
Is there any federal code when it comes to electrical codes?
federal monies helping fund non federal projects is not necessarily the same thing as building a federally owned facility where they may not necessarily need to comply with local jurisdictions and their codes. I've worked on projects where federal funds were used to fund the project or portions of it, most the red tape was with labor laws but installation codes was still per local jurisdictions.
There get plenty of federal money for projects and use their electrical code. The Chicago 2018 Electrical is a highly amended version of the 2017 NEC. The following are examples of amendments for MC and NM cables.
14E-3-330 Metal-Clad Cable: Type MC
The provisions of Article 330 of NFPA 70 are adopted by reference with the following modifications:
1. Revise section 330.10 to read:
“Uses Permitted.
(A) Existing Installations. Except where otherwise specified in this Code and where not subject to physical damage, listed Type MC cable with listed fittings and not exceeding 7.62 m (25 ft) in length between junction boxes shall be permitted for branch circuits in concealed work fished into existing walls, partitions, floors, or hard surface ceilings where other work does not require or include removal of the existing finished surface.
(B) Exposed Work. For exposed work only under the following conditions:
(1) In lengths not more than 1.83 m (6 ft), at terminations where flexibility is necessary;
(2) In lengths not greater than 1.83 m (6 ft) in accessible, but not habitable, attics and roof spaces where installed in accordance with 320.23;
(3) In lengths not greater than 1.83 m (6 ft), below the basement ceiling joists where it is necessary to connect a cabinet or junction box.”
2. Revise section 330.12 to read:
“Uses Not Permitted. Type MC cable shall not be used for any installation not permitted in 330.10.”
14E-3-334 Nonmetallic-Sheathed Cable: Types NM, NMC, and NMS
The provisions of Article 334 of NFPA 70 are adopted by reference with the following modifications:
1. Revise section 334.10 to read:
“Uses Permitted. Type NM and Type NMC cables shall be permitted to be used in the following:
(1) Temporary wiring for branch circuits as permitted in 590.4(C)
(2) Temporary wiring as permitted for feeders as permitted in 590.4(B)
(3) Limited extensions to knob-and-tube lighting or appliance branch circuits in existing dwelling units in buildings not exceeding three stories in height.”
2. Revise section 334.12 to read:
(A) Types NM, and NMC. Types NM and NMC cables shall not be used for any installation not permitted in 334.10.
(B) Type NMS. Type NMS cables shall not be used.”
