Who invented the MEGGER??
brother said:
do you know when? and where did you get this info that i can see for myself.
Late 1800's early 1900's. He invented just about every electrical meter.
Here's a link to a writeup about him. I would put him into the genius category, myself.
LINK
LINK 2
From the second link
Edward Weston invented electric motors, potential transformers, current transformers, A.C and D.C. voltmeters, ammeters, wattmeters including polyphase, ohmmeters, both A.C and D.C laboratory standards, standard cells, panel meters in hundreds of sizes, shapes and ranges, power factor meters, control relays, tachometer generators, A.C and D.C. amplifiers, radio tube (bulb), radio test instruments, insulation testers, multi-range, multi-purpose industrial circuit test instruments, mutual conductance electronic radio-tube analyzers, A.C. industrial test units, A.C clamp ammeters and voltmeters for powerline works, moisture measuring meters, electrical and mechanical recorders and controllers, thermometers mercury tube, thermocouple and bimetal types, hydrometers for all branches of chemistry, ground detectors, humidity indicators, meggers, frequency meters, sensitive relays, laboratory standard electrical measuring instruments, aircraft navigational and engine condition instruments, including the first-blind landing instrument in 1933, switchboard instruments, shunts, resistors, D.C. galvano-meters thermal converters, copper oxide rectifiers, projection instruments, VU meters, photoelectric cells initally used in illumination meters, light meters and foot-candle meters.
