benaround said:A co-worker asked me today what the mark on a measuring tape at every
19.25" is, It was the first time I ever knew it was there. Anyone know?
benaround said:By the way, how do you know this stuff?![]()
peter said:The history of the cubit goes way back to when God ordered Noah to build the Ark. My dictionary states that it is based on the length between the elbow and the wrist and varied between 17" and 21". ~Peter
A cubit is from the elbow to the end of the middle finger, as I have been taught. FWIW, mine is 19 3/4" and I think it's cool to find out that Stanley standardized it and put it on his new invention.peter said:The history of the cubit goes way back to when God ordered Moses to build the Ark. My dictionary states that it is based on the length between the elbow and the wrist and varied between 17" and 21". [/COLOR].
~Peter
What is the diamond marking on tape rules?
Answer The black diamond marks every 19.2" on our tape rule blades are for spacing joists and studs. Several wood product manufacturers offer Engineered Lumber as a substitute for conventional lumber. Span tables for these lumber products provide ratings for spacing of 12in., 16in., 19-3/16in., and 24in. If you multiply these dimensions by 8, 6, 5 and 4, respectively, you'll notice that you come up with 96in., the length of the panels that will be used for sub-flooring or sheathing. Engineered Lumber is usually specified by the architects and engineers who draw the plans. They take advantage of its strength by using fewer joists or studs where codes allow.
cubit
Main Entry: cu?bit
Pronunciation: \ˈky?-bət\
Function: noun
Etymology: Middle English, from Latin cubitum elbow, cubit
Date: 14th century
: any of various ancient units of length based on the length of the forearm from the elbow to the tip of the middle finger and usually equal to about 18 inches (46 centimeters)
"Let's see, I used to know what a cubit is..."brian john said:God said to Noah "I want you to build me an ark (so many) cubits by (so many) cubits."
Noah said to God "What's a cubit"
Bill Cosby 196?
peter said:And the similarity between 12 inches and the length of someone's foot is also strictly a coincidence. Yeah right!
~Peter
