N nizak Senior Member Jan 4, 2025 #1 Correct me if my missing something. If the Emergency disconnect is shut off, won’t the generator start and provide power to the dwelling?
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Jan 4, 2025 #2 Yep.
N nizak Senior Member Jan 4, 2025 #3 LarryFine said: Yep. Click to expand... Are there requirements in the code to also turn off generator power or just Utility power?
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Jan 4, 2025 #4 I believe it's covered by required labeling of there being multiple sources.
Seven-Delta-FortyOne Goin’ Down In Flames........ Location Humboldt Occupation EC and GC Jan 4, 2025 #5 What Larry said. All the ATS i install have a label that you fill out showing where the gen is located. And the generator is required to have an external shut off switch.
