ljelectric
- Telford, PA
It has been stated by local inspectors that when you install a whole house generator with a main breaker transfer switch. If the house was wired with a 6/2 romex range connection, you now have to replace the wire, receptacle and cord with a 6/3 romex, so that the neutral and the ground are fully separate since you had changed the main panel into a sub panel and have separated the neutrals and grounds. Is this correct?
