tonype
- New Jersey
Meter is too high for my area.
Clearance issues.
No lock on meter..... is that a POCO-owned meter?
What is on the outside, there isn't another meter on the outside?
...............What is to keep the homeowner from tapping off the service before the meter?
Cold sequence metering. Some utilities sometimes allow it.
If you reversed the locations of the meter and the disconnect, the service conductors would run more than necessary before going to the disconnect/OCP. The inspector might of had an issue with that.
Strange to see a meter on the inside though. Is there no room for it outside?
My guess is that there isn't any room on the outside for the meter and disconnect, and the utility company allowed a non-standard install.
No room outside.... this wall is smack on the property line (Jersey City). Not sure if POCO has yet to approve, since rope is holding the service drop to the service hook temporarily.
More like they require it. It is most popular with 480/277 and 200 amp and less with self contained metering.Cold sequence metering. Some utilities sometimes allow it.
