StevieP007
I friend of mine asked me this the other, and I felt like I should've kown this,being a licensed electrician, but it's just one of those things that I never asked or just took for granted;
When testing across 2 ungrounded wires of a 3-phase 277/480 volt panel, the meter reads obvoiusly 480 volts. Why does it read only 277volts when going from 1 leg to ground or neutral, and not 240? Or 554 volts when going across 2 277volt legs? I'm pretty sure it's because of either the way the secondary side of the xfmr is tapped, or the fact that it's a "y" secondary just about 99% of the time. I just don't understand the reasoning why this is.
Any explanation or linked picture would be greatly appreciated. thank you.
[ November 23, 2004, 10:25 AM: Message edited by: StevieP007 ]
