ptonsparky
Tom
- EC - retired
What is the advantage of a three phase 400-500v AC to 24v DC power supply when the need is only 2 amps or less? Is it worth the dollars?
The issue is that using a 400-500V auto-ranging power supply means you don't need another transformer (like a CPT) to step down the line voltage to feed the power supply input. Then 3 phase vs single phase makes the package more compact and less expensive because of needing less capacitance to smooth out the ripple. The mfrs feel that if you have 480V, it's a 99% chance it's a 3 phase source.
