Why a GFCI trips????????
Nietz001
St Paul MN
I have a new installation; GFCI's (120volt) were installed outside a building to accommodate food service equipment. I have experienced nuisance tripping on a random basis at the receptacle's. Either the GFCI?s are working properly and the equipment is to blame or the GFCI?s have an issue. Perplexed? anyone had this problem? Not sure where else to look. (The equipment is brand new)
Excluding excessive moisture at the receptacles or cord caps I would say the equipment is the problem.
Roger
Chances are good the problems are in the equipment, also, if two or more items are on
the load side of a gfci recpt. and they all 'leak' just a little it will add up and trip the gfci.
