marmathsen
- Seattle, Wa ...ish
- Electrical Contractor
I'm really just whining here but, why the heck are PVC LBs and other conduit bodies so dang sharp on the inside lips? It should be required that they are manufactured with a smooth edge.
On a related note, is there such a thing as a long LB? For instance a 2" with a longer than standard opening so you can easily bend larger wires into it?
(Here's where someone chimes in and says you can buy both smooth edge and long body LBs)
Rob
Rob G - Seattle
Rob
Rob G - Seattle
