brother
Well , I was on a call and this was at a house. The service drop/power was damaged and had to be disconnected (cut from the service from the pole), even with all the power disconnected, the lineman/poco guy was moving the mast guy from service to another and and he got shocked!! He was ok.
it was only about 80 volts and what turned out to be was the voltage between the ground from the cable company equipment and the neutral/grounded conductor. not sure where the cable company was picking up the stray voltage (maybe from another house or on their own equipment somewhere down the line) , but with the 'bonding' this stopped this from happening.
Just a heads/safety up, even with the service disconnected from the pole, be sure to double check with a 'power wand' or 'tic tracer' to be sure the power is off!! . This was the first time I ever saw this type of shock this way.
