Mrat
- Granite Bay, California
I recently installed a subpanel in a new garage which is fed from a pool subpanel which is fed from the meter/main. The new garage has a ufer ground that I installed a ground wire to. The pool panel feeds the garage subpanel with a 2 pole 40 amp breaker. I failed my inspection because the screw in the neutral bus bar that connects it to the sub panel enclosure and thus the ground buss bar was not bonding the neutral to the ground. Why is this done? I was not there to quiz the inspector. The garage is detached and separate from the house. The pool subpanel is fed with 4 wires H-H-N-G as is the garage subpanel. Can you explain why this is done? I have tried to look at posts going back to 2003 in this topic without luck. I appreciate your responses. Mark
