Why do people spend all the money on LED retrofitting troffers?
Only to make them perform worse :lol:
http://apps1.eere.energy.gov/buildin...er_21-2_t8.pdf
"Fluorescent-lamped troffers were always preferred for appearance and comfort, compared to the same troffer lamped with any of the linear LED lamps. However, both of the LED products with a diffuse aperture?the medium LED and wide LED?were generally rated as acceptable."
Can you post the link that directly links us to the article you want us to read?:)
You pasted in the shortened display text of the link, not the full link itself.
We get it, you don't like LEDs. :D
I will keep installing them as long as people keep paying for it.
There is definitely a niche for LEDs to replace CFLs, even if linear fluorescents are more efficient and give better color quality for the moment.
Not every situation allows troffers.
Exactly what iwire said. As far as performance, lets see, you get rid of a ballast and get rid of a mercury filled device and a light that is usually rated between 40-50K hours, I don't get how the LED's lack in performance. Also, you get a green cast with fluorescents unless you get lamps that have been color corrected with magenta which can give off a purple hue. And true, you get some green cast with LED's but you just need to find ones that have a high CRI and tunable color. Don't see how you can wrong with that. It took me a while to find ones that impressed me but I have found them.
I don't doubt there are reasonable applications for LED's. But "40-50K hours"? I'm reminded of the following from Third Rock From the Sun:
Dick: I think we've underestimated the life on this planet. The people have so much courage. Here they are hurling through space on a molten rock at 67000 miles an hour and the only thing that keeps them from flying out of their shoes is their misplaced faith in gravity.
Leave 1,000 or so on for the next 5 years and get back to me on the MTBF.
Oops, not sure how it got copied like that. This is the working link where I got the quote that people surveyed generally preferred the fluorescent lighting technology
http://apps1.eere.energy.gov/buildings/publications/pdfs/ssl/caliper_21-2_t8.pdf
LEDs do have applications, but they're not quite the same as transistors are to vacuum tubes.
]exactly what iwire said. As far as performance, lets see, you get rid of a ballastand get rid of a mercury filled device and a light that is usually rated between 40-50K hours, I don't get how the LED's lack in performance.
Absolutely wrong. LEDs and fluorescent utilize a very similar power supply which is an added point of failure that equally disadvantage both technologies. It's actually becoming more similar. Higher voltage LEDs are getting utilized and a string of LEDs operate at about the same level as fluorescent lamps.
There are inferior quality sytems that do not use an external inductor or capacitors solely to reduce production cost. They're a leakage that is slipping past the current loop hole in SSL standards which is still in its infancy and do not address flicker measures. It's like going back to magnetic ballst, but worse, because phosphors used in solid state fluorescent LEDs have a short persistence and emphasizes the effect of 100 or 120 Hz flicker. "mercury" is a cheap jab used by LED advocates. Semiconductor factories are rather environmentally dirty.
All low pressure mercury discharge fluorescent lamps produce a few distinctive mercury lines which causes a green cast on photographic films due to the differences in sensitivities from human eyes to film emulsion. Most solid state semiconductor fluorescent lamps (LEDs) have a distinctive spike around 450 nm in deep blue region.
Human eyes, CCDs, CMOS' and film all sees in color but the characteristics in the way it responds to spectrum is different. A light source that's rich in output in spectrum where our eyes have dull senses don't affect the color rendition much. If the sensor device is more sensitive to this spectrum than our eyes, it will affect how it's captured a lot.
You bring up an important subject. LED industry rates their life at L70, a prediction of when 30% of lumen otuput is lost. Chromaticity is measured using MacAdams Ellipses delta 'uv. Modern fluorescent lamp technology only loses less than 10% output in lifetime and 50,000 + hour rated fluorescent lamps are readily available.
There is another parameter for LEDs called L90, which is the point of 10% lumen loss. I think this needs to be PROMINENTLY and display both the new value and L90 value as fluorescent lamps do. The crap fluorescent lamps that lose 30% of output are not in common use. That's the technology of the obsolete 110W cool white HO lamps.
LEDs are susceptible to color shift with use. It is likely to be the factor that condemn decorative light emission products even if the lumen output is within specs. This type of failure is NOT covered by warranty on LEDs by conveniently defining a type of degradation that renders them unfit for use, but still lighting up.
They've done some field observations on this very troubling concern about LEDs.
http://apps1.eere.energy.gov/buildings/publications/pdfs/ssl/2013_gateway_color-maintenance.pdf
Don't see how you can wrong with that. It took me a while to find ones that impressed me but I have found them.[/B]
I think they use GaAs type like red LEDs, which contains the highly metal arsenic. It also adds complexity to controls and possibility of light quality degradation like infusion of PWM modulation flicker. This isn't an LED exclusive domain. Fluorescent luminaries could use equally complex control gears to mix output from multiple lamps the same way it is done with LEDs to produce tunable color output.
It stands to reason that a light fixture designed with a lamp in mind that distributes 360 degrees uniformly will not perform or look the same when replaced with a source that is directional.
The larger issue I see with the LED T8 replacement lamps is the violation of the UL listing of the fixture assembly in order to install them.
This is an entirely different product than a fixture that is designed around LEDs as the light source, for which there are many good solutions that are far better than their fluorescent counterpart.
Shoe,
Your point of 360 degree light vs. directional has come up while researching whether or not to swap 175 w MH lamps with retro fitted 50 w LEDs. These are can lights shining down from 21'. What do you think about the idea that so much light is wasted when the useable light is the light that shines downward?
Just gathering info. Sorry to hijack the thread.
I was mainly speaking about T8 replacement LED lamps for troffers.
For "can" lights LED's are a no-brainer as far as I'm concerned, since a can is essentially a "downlight" traditional lamps are very inefficient for this type of fixture. (typically 40-60% efficient)
But I'm not familiar with the 50W LED replacement lamp you reference, so I can't speak to its quality.
For troffers, the efficiency of the reflector and diffuser can vary greatly among models.
The reflector issue is part of the efficiency improvement when switching from T12 to T8 or T5.
A linear LED will show a greater improvement in delivered lumens per watt when used in a troffer that was poor to start with.
They can also cause a strong shadow casting inferior quality light that makes you look like you're lit under a spot light. If you remove the opal diffuser on an incandescent fixture, it increases the efficiency quite a bit too, but causes them to have an LED like glare.
