Re: Why do some hot tub manufactures use a 3 wire system and
I just don't understand why hottubs arent required to have a 4 wire system. After all there are metal components on the display boards. I guess these manufactures have thought this out, it just seems 4 wire should be required
Ace, what would you do with the extra conductor as it may not be needed. All hot tubs require a separate grounding conductor.
In no case can a hot tub use the neutral to ground metal parts like dryers and ranges where allowed to.
A hot tub with a 3 wire feed is either straight 120 volt, with no 240 volt components
1)Hot
2)Neutral
3)Ground
Or it is straight 240 volt, no components need 120 volt
1)Hot
2)Hot
3)Ground
A 4 wire hot tub would be 240/120, some components use 120 and other components use 240
1)Hot
2)Hot
3)Neutral
4)Ground
A typical water heater is straight 240, no neutral needed
A typical dryer has 240 volt heaters, and 120 volt motor, controls and lamp(s). Because there are both 120 and 240 loads the dryer now gets a 4 wire feed.
i need an easy way to say to a 10 year old.
Kind of young for a apprentice.
Bob
