Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
I think its a good idea to leave a few wraps. But the picture Hal posted is a bit much. That control could be replace 200 times without running out of wire
Dunno about that. Is that the Klein 603-4B? From the description it sounds like it's made for us:Klein still makes a BSP screwdriver with a extra pin offset in the bottom of handle to support 18- 24 AWG when you curled wires.
The Mickey Mouse ears in a panel are not necessarily useless. Aboard ships, they are called burn-back loops and are specified in the notes to plans frequently, although I expect this is going away slowly. The reason being that all ABS ships are wired with LSZH cables which are finely stranded. As we know, just terminating this type of cable in a "terrestrial" panel (they use special marine panelboards on the interior of the vessel) can cause overheated/melted terminations. This is going away with the use of crimp pins or ferrules.It's to leave slack. No guarantee that was done by a plumber and not an electrician. This is still better than the Mickey Mouse ears in a panel.
Sorry. Re-read my post and there was a typo. They generally DO NOT use special marine panelboards on the interior of ABS classed vessels.The Mickey Mouse ears in a panel are not necessarily useless. Aboard ships, they are called burn-back loops and are specified in the notes to plans frequently, although I expect this is going away slowly. The reason being that all ABS ships are wired with LSZH cables which are finely stranded. As we know, just terminating this type of cable in a "terrestrial" panel (they use special marine panelboards on the interior of the vessel) can cause overheated/melted terminations. This is going away with the use of crimp pins or ferrules.
However, many ship systems are critical and in the case of failure due to overheating, the crew member would open the panel, cut away the melted section and re-terminate to get the circuits back on line as quickly as possible.
Mark
And, you can't just "tack on a few extra inches" on some cables (e.g., CAT5/6, RG6, etc.) so having slack "stored" is a win. Wire choice also plays a role -- solid being more likely to break off at an inopportune time.I actually agree. Some slack is good for the reasons you state.
-Hal
