Why doesn't the NEMA 6-50 plug go into the 14-50 receptacle?
rszimm
Tucson, AZ
This is something I've always wondered about. When they came out with the 5-15 standard, they made it backwards compatible with the old 1-15 (i.e. a 1-15 plug will go into a 5-15 receptacle.). It would seem that a similar argument could be made for the 6-50 plug going into the 14-50 receptacle and just picking up the two hots and ground. I'm sure there's got to be some history behind this as it seems like it should be obvious to me...
NEMA 14 is not three phase. (maybe you're thinking of 11, 15 and 18, which are 3 phase?). INEMA 14 is hot-hot-neutral-ground whereas NEMA 6 is hot-hot-ground. If they had designed the 6-50 plug "correctly" it could plug into the hot-hot-ground ports of the 14-50 receptacle. As it is, it's just a tad too narrow to fit...
