- Windsor, CO NEC: 2017
- Hospital Master Electrician
Edit: Found a picshur!
[ May 12, 2005, 08:11 PM: Message edited by: georgestolz ]
But only for a very small area. About 80% of the voltage on the ground rod will be dropped across the earth within 3' or so of the rod.It also helps to keep the earth potential of the area around the temp service at the same earth potential.
