K8MHZ
- Electrician
I learned something today.
OK, so I have an old Chicago bender (a real one, made in Chicago) that someone cut the wheels off. I also have a newer one, the next size up, and am using it for a pattern to make the old one moveable again and have them both look the same.
So, I get a couple wheels that take a 1/2" axle. An off the rack 1/2" steel rod fit perfectly.
Next, I needed a piece of pipe to slide the axle into. That pipe would be welded to the bender. A trip down to the hardware and all they had was 1/2" black pipe and it was sloppy. I bought it anyway, but started to look for a better fit.
Here are some specs. 1/2" black pipe .622" I.D.
1/2" RMC, .632" I.D. , which is larger than 5/8"
With a bit of research, I found out why.
http://www.gizmology.net/pipe.htm
Oddly, there is nothing about a ?" pipe that is ?", be it copper, iron, or PVC. The outside diameter of copper is 5/8", and the inner diameter is either 0.527", 0.545", or 0.569", depending on the series. So-called ?" iron pipe is 0.840" outside diameter and 0.622" inside. PVC is the same outside as cast iron, but it is 0.608", 0.528", or 0.480" inside.
If no dimension is ?", why call it ?" pipe?
Well, it seems that back in the beginning of time - copper pipe was introduced in the 1930's - copper pipe was indeed standardized at the nominal diameter inside with a 1/16" wall, making it 1/8" bigger on the outside. As the metallurgy improved, allowing manufacturers to use thinner metal (and thus increase profits), they increased the inner diameter rather than decrease the outer diameter simply to allow the pipe fit existing fittings.
As the manufacturers began to make bigger and bigger pipe, they found that 1/16" wall thickness was insufficient. Thus, the inner diameter of larger pipes is smaller than the nominal size, while smaller pipes are larger.
Wrought iron pipe has a similar history, though I don't know the details. When PVC was developed, it inherited it's outside diameter from iron pipe.
