Interesting its here also but considered 'legacy' do they keep the ungrounded delta on upgrades?And this actually makes the case for how little the resistance of the grounding electrode system really matters. Many places of the country have lots of ungrounded Delta distribution. Most rural areas in upstate New York where I live are this way.
I wonder if thats because of that big court case on Electrical Trespass or "Stray Voltage" from a what I think was a MGN system in NY. However I might have that backwards it may have been a delta system.So a building served from these won't have the massive MGN grounded in a zillion places. Instead they will just have an earth connection at the pole, with a good chance that has been cut off and stolen by thieves. That leaves the electrodes at the building as the only Earth connection. My point is I have never noticed an increase in surges, damaged equipment, less reliable operation, or anything negative whatsoever on these systems compared to one served by an MGM with its super low resistance ground.
Some homeowners had high levels of stray voltage around a substation after it was 'upgraded' back around 2012 they sued.
I think they (the plaintiffs) proved the Utility (NYSEG) was aware the (MGN?) system caused stray voltage.
The utility tried to fix it by installing the fancy 'Ronk voltage blockers' etc.
Basically a utility is liable for 'Inverse Condemnation' when their (neutral) current leaks across a property causing a 'loss' as then you cant enjoy your new pool or your dog gets shocked etc. Even if a utility has an easement for electrical wires, they need a different easement for using the earth as a conductor. There have been recent successful suits that utility easements for electrical wires dont cover 'fiber optic', due to the exact wording of utility easements, though some may allow SWER or MGN explicitly.
I cant remember the outcome of the case but I remember it was in NY and it cost the utility millions just in legal fees, was big enough that other utilities started reconsidering upgrading to that system as 'risky'.
There have been other cases around dairy cows and pools.
