Stevenfyeager
- United States, Indiana
- electrical contractor
Why is SEU or SER different amperage rating than Romex ? Why are the SE cables rated higher than Romex ? SE uses the 75 column and NM uses the 60 column, am I right ? They are both jacketed. Just different type of insulation ? With 6-3 Cu costing $ 5 to $ 6 per foot here, does anyone use #4 SER for ranges now ? ($1.25 ft) (Both rated for 55 amps?) Thank you.
