samgillis
- California, USA
- Electrician
I live in SoCal and believe I am seeing the mainline neutral on poles getting its own fused cutout.
While I’ve heard there is a lot of ungrounded delta in this area, I’ve also been told by an Edison worker that there is 4 wire wye distribution, as well.
I know the pictures aren’t the easiest to see, but the one with the pole xformer shows the two outer lines being tapped to feed the primaries, and when I went further down the road and found where the lines were dropped underground to go into a neighborhood you can see that the two outer lines have red and white tape on them, respectively.
The white tape tells me that must be the mainline neutral, right? But why would they fuse it? Could it be that it’s not a MGN distribution and they only ground at the xformers, making the mainline neutral have a high enough voltage to ground to warrant fusing it (since the wire distance back to the sub xformer is quite far)?
