Code section 250.66(A) permits that GEC doesn't have to be larger than #6 if it is the sole connection to a grounding rod.
But why is it required that we have to follow 250.66 if it is connected to water pipe?
I had a debate with a local inspector that they follow 250.66 even if it is the sole connection to a ground rod.
He said "it doesn't make sense not be larger than #6". The only reason that i see they strictly follow table 250.66 is because of 90.4.
