Shackled Designer
- Decatur, AL USA
It seems that in attempting to find DC fuses, there is a fairly broad range of amperages available if I use normal or fast-blow fuses, but for slow-blow, the available range seems to be small and divided. In particular, I failed to find slow-blow, DC-rated fuses at all from two of the three usual fuse vendors, and the third which did have them has a gap in the DC ratings above 3A and below 12A. Wouldn't you know I happen to need a 4A, slow-blow, DC-rated fuse.
I realize, of course, that DC fuses are a bit more involved in their design than AC fuses, so does this gap in the offering reflect a technical problem in producing, or is it simply that almost no one wants DC, slow-blow fuses in this range?
Perhaps I should consider a DC-rated MCB . . .
Explanations and suggestions are welcome.
Ponderously,
The Shackled Designer
Ponderously,
