electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
Grounding versus bonding? Huh?
how 'bout two stars * *Originally posted by charlie b:
You get two Brownie Points.
If it makes you feel any better, I thought it was pretty funny.Originally posted by georgestolz:
Edit: Not even a snicker?![]()
I once coined a phrase to describe this very concept. I call it, ?Precision Ambiguity.?Originally posted by physis: I think at some point the only way to be legally safe will be to mumble or scribble or use whatever other means to be vague and not actually convey an idea.
The problem is that the word grounding is used in the NEC for both bonding and grounding creating much confusion in the field.Earth grounding of systems, and the bonding of equipment and conductor enclosures, are two distinctly different procedures in principle, and both are required.
