Bill Snyder
NEC expert
- Denver, Co
- Electrical Foreman
Breaker ampacity would have nothing to do with GFCI function.To keep the GFCI from tripping.
Yes, for some 30 years now.Aren't all breakers now HACR?
GFCI is not requiredTo keep the GFCI from tripping.
The manufacturers minimum circuit ampacity used to be based on the NEC that states we must go 125% of the unit FLA.We are having a debate as part of the myth of the week, why does the manufacturer post a minimum on their nameplate since there is no minimum as long as the A/C starts?
As I see it, without the stickers shown, I can use whatever BC protection, >or= to MCA, I want as long as it does not exceed the MOP. NEC does require the unit to start with that protection.The manufacturers minimum circuit ampacity used to be based on the NEC that states we must go 125% of the unit FLA.
