zappy said:
could a loose or bad connection at the socket cause a fuse to trip??
I don't know about your particular situation, but loose connections get hot, and fuses blow because the element gets hot enough to melt. Seems you should have seen some indication , discoloration... connected wires with melted insulation.
zappy said:
i opened everything that was dead on those circuits could not find any shorts
Part of what is hard about troubleshooting, is not knowing what is connected to the circuit.... If these were all receptacles, after unplugging everything, you should have been able to read them all with an ohmeter from the fuse box . Making sure everything is unplugged is easier said than done sometimes.
You have to be able to read the ohm meter and decide if the reading makes sense for what should be connected. If you divide the voltage involved by the resistance it should indicate whether the circuit has a problem or not.
A motor will have a low dc resistance. If you find a circuit that has a low ohm reading, find out what is connected.
zappy said:
.put a ohm meter on the hot side and the neutral side of a dead outlet and got a tone.all the switches where off,nothing was plugged in
If your ohmeter is working, there is some connection between the hot and neutral... It may have been useful to note the actual ohm reading. It might have helped you determine what was connected.
zappy said:
i was desprate so i screwed in a new 20amp fuse in one of the sockets.didn't blow.and every thing was on working fine the other socket had no fuse in it.so i was thinking when you put in the other fuse it blows both because of a bolted fault some where
zappy said:
also there was some shotty work in outlets and switches so i knew somebody has been doing some electrical work that didn't know what they were doing.like using the ground as a neutral
well they didn't want to keep me on the clock anymore and everthing was working now so got paid and left. is there a blank fuse to put in that open socket?
It seems like you are bothered because you didn't find the problem to your satisfaction. Being conscientous is not the worst trait in the world. :smile:
If it is bugging you, you should talk to your boss about it.
Edited: Holy mackeral I'm slow
