serenity5807.wt
New member
I'm installing a 20amp 240v roof heat system that requires a gfci breaker. I had a 2 pole 40amp feeder to outdoor disconnect for ac condensor originally. I eliminated disconnect switch and made it an out door subpanel to feed roof heat and condensor. Since no neutral was ran for condensor originally, do I have to run a new feed from panel just for gfci breaker? Or will it still function properly without it
