I know this is an easy one for most, but it can hang up even the most seasoned electrician that has a bias in his thinking. When you see the problem, what's the first answer that comes to mind?
Ok, we have a 110-volt toaster, 1000 watt, on a 15 amp circuit.
The new apprentice (JW would never do this) lol, takes off the neutral and wires it to 220 volts. Still, 15 amp circuits.
Will it blow the fuse?
