bbeell@live.com
- california
Word of Mouth for quality work runs far and wide, but dispersed.
Routing three 10/2 UF cables through and out of a house interior wall down the exterior of the wall, Using a PVC 90-degree elbow, down exterior wall through the roof of a connected shed.
This is a common wall shared by the shed and the house.
PVC conduit will be used beginning at the exterior wall until the cable reaches each of the appliances.
Would it be wise to use one elbow exiting the house wall, in one PVC conduit pipe down the exterior portion of the wall, or three separate elbows, and three separate conduit pipes.
Because this is a makeshift shed, PVC conduit will be used even after the conduit branches off in route to each other appliances.
When three cables run through the elbow and PCV pipe what size conduit should be used?
When one cable runs through the PVC elbow and conduit what size conduit should be used?
Any tips and suggestions would greatly be appreciated, thank you
