Have an old old A/C unit, 230/208V, 15.8A/16.5A with no max CB size listed since that was not a requirement when it was manufactured.
It is clear that the CB size must be 30A on my 208V circuit. But what wire size needs to be used? I have an existing circuit that is #12 that I would like to use. If it were a regular motor circuit #12's would be fine.
California Elec Code (1999 NEC) Art 440 Part D (Branch Circuit Conductors) section 440-33, ex 2 says that for conductor sizing Part 'G' applies.
Part G says that the appliance shall be treated as a single motor appliance where all of the following conditions are met: 1 - cord and plug connected , 2 - not over 40A 250V, 3- Total rated load is on nameplate, 4 - Branch circuit CB/Fuse does not exceed ampacity of the wiring.
What if the four conditions are _NOT_ met? I can't go back to 440-33 because it directs me to Part G. I'm going around in circles!
