Fitzdrew516
- Cincinnati, OH
I'm drawing a blank. I need to find the section in the NEC that states that you can use wire with an ampacity rating that is less than the main breaker size as long as your load does not exceed the wire's rating. For example - your service main is 2000A - I've been told that you coud use (5) sets of #500 kCMIL on the 2000A main breaker as long as your load doesn't exceed (in this case) 1900A. Thanks.
- Drew
- Drew
