Ok
Do you know that thin wire that looks like then but it's real thhn and aluminum colored that gets jumped load side of motion detector going to the two flood lights usually spliced with a crimp wire connector on big box store motion flood light combos ? What would you think the amperage rating for that wire is.
Reason I ask is I had a situation with two single fixtures. One on each side of an entrance door that each light was equipped with a photo cell, motion detector, and single bulb outlet rated for 60w (sticker)
One light failed so I took the load from one sensor to feed the working fixture and the bulb from the other fixture.
The load wire from the sensor was that same size wire used on double headed flood lights as described above.
The actual rating on the switch sensor says 300w
Would it be safe to assume that that load wire built inherently in that switch would be rated for 300 watts and not the 60 watts that is on the sticker by the socket.
Would you think that wire would be at least rated for 1 amp
I know it would be guess but just asking
Thank you.
Thank you.
